• 16.04.2026, 22:03
hey_its_meeee
Show High Flow NEXT virtual sensors into the display
Sonntag, 21. September 2025, 17:58
Hello everyone, new member here.
My build contains 1 water temperature sensor connected to my Aquacomputer OCTO. I also have the Aquacomputer High Flow NEXT, showing water temp from its internal sensor, so far so good. But I want to know if there's a way to show the data of my OCTO water temperature sensor into the NEXT display.
In Aquacomputer suite, I've created a virtual sensor using the data of my OCTO water temperature sensor and imported the data into one of the NEXT software sensors but I've yet to find a way to display it on the NEXT display.
1 solution is to use the external temp connector of the NEXT, but I prefer not to, for now (since all my fans and pump are controlled via the OCTO hardware and the water temperature sensor connected to it.)
Any ideas?
SgtSixpack
Sonntag, 21. September 2025, 18:08
