• 04.04.2026, 08:24
pantheo91
D5 Ultitube RGB led ring not working
Montag, 20. Oktober 2025, 12:50
Hello everyone,
I have installed my new D5 Ultitube reservoir 200 along with Shield and the RGB led ring is not working. I have installed as manual said the plug into the IN port but nothing. Shield and D5 rgb is working but not the ring.
Any suggestions? https://ibb.co/Fb3fnL62
Thanks in advance
Montag, 20. Oktober 2025, 13:31
Make sure that the port ist set to RGBpx (aquasuite: D5 NEXT - > System)
pantheo91
Montag, 20. Oktober 2025, 14:49
That is correct, you're a life saver. Thank you for your help
