• 05.04.2026, 01:48
Tanquen
My controllers for some fans disappeared yesterday, I had to recreate them. Then this morning I got a virus warning.
Freitag, 28. November 2025, 17:00
A few days ago I removed the D5 Next as it was starting to get noisy and I wanted to get a 5090 and didn't want to pay for a water block and spend the time rebuilding my open loop.
(I got an MSI Suprim Liquid RTX 5090, I've had my custom loop for years and was spoiled. It's really disappointing that this AIO with a 360 Rad is so loud. I just don't have the energy anymore, to go back to purchasing $500 water blocks installing them dealing with the coolant and so on. It sucks getting old. :( )
Then all the controllers for the fans disappeared and I had to recreate them. I don't believe anything had to do with the D5 Next, not sure why and they all disappeared. They all defaulted to some preset value relay object. ???
I tried to run an update and the licensing looked weird so I went ahead and bought another year for Aqua Suite. Then this morning I got a virus warning about the application but I think there was actually an update available?
I'm not sure why I didn't get the warning previously? Something was updated or the Microsoft virus Scanner updated its signatures maybe?
VulnerableDriver:WinNT/Winring0
file: C:\Program Files\aquasuite\AquaComputerService.sys
Tanquen
Freitag, 28. November 2025, 20:01
Now I can't get CPU temperature. Is it related?
Now when I go to select a data source for a software sensor under the AMD Ryzen 9 7950X3D CPU there's just the one core temperature that's stuck at zero Yesterday there were many other options to select from.
https://forum.aquacomputer.de/weitere-foren/english-forum/114285-information-about-windows-defender-warning-hacktool-win32-winring0-aquacomputerservice-sys/
I thought I had updated to v84 but I hadn't.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Tanquen« (28. November 2025, 21:13)
