• 05.04.2026, 03:17
S1cc0
Moving to new OS, how to do a complete backup for migrating
Dienstag, 13. Januar 2026, 18:24
Tried searching for this, but posts I found did not really contain a 100% verified method.
What do I need to backup if I want to keep everything exactly the same?
JasonMorris
Dienstag, 13. Januar 2026, 20:26
For Aquasuite software settings just export your pages to disk and then import them after the install. If you have any custom graphics etc remember to keep them also. These by default go into your C:\ProgramData\aquasuite-data folder
For each hardware device such as pump or Aquaero go to it's system settings and "export active settings to file" then import after the install. These by default go into your Documents\aquasuite\profiles folder
I've done it multiple times with no issues.
