• 14.04.2026, 14:11
Endless
Maximum value for Bar Graph (or convert MB to GB)
Sonntag, 25. Januar 2026, 17:10
I'm trying to stick a bar graph of my GPU memory on a sensor panel but I can't use the raw MB number because the bar graph won't allow such a large End Value, and I can't find any way to convert the MB to GB. Is there any way to extend the maximum end value, or even better convert the MB to GB?
Endless
Sonntag, 25. Januar 2026, 17:41
It looks like virtual sensors were the answer. I've never played with them before, but in Playground->Virtual Software Sensors I just made a really simple system with GPU memory as input, static value of 1024, X=A/B math component, and output that as the virtual sensor value. Then I can use that as the data source for the chart.
