• 22.11.2026, 20:19
Levvy
Leakshield with fountain effecton aqualis
Samstag, 11. Juli 2026, 20:42
Hello,
As far as I know Leakshield works by sucking out the air thru membrane.
I have aqualis 450 PRO with fountain effect in my loop.
Now I want to add LEAKSIELD on top of it.
Will it work when I only replace top lid with LEAKSHIELD?
I cannot find any information on it. Have anyone made it work? Or it would break the system?
Montag, 13. Juli 2026, 11:06
I can only tell you that if the membrane gets wet, Leakshield won't work again until it is completely dry.
