• 10.01.2026, 12:44
SpeedyGonzales
USB extension from motherboard?
Donnerstag, 10. April 2008, 16:11
Hi!
I have a Aquastream Ultra, Aquaero, Multiswitch, Tubemeter.
I also have a flowcontrol.
If I connect all this to USB on mobo, I have no free for cabinet USB connection.
Is there a way to lets sayI take 1 from mobo, and extend it into 4 5pin USB connections for my equipment?
Speedy out!
etoel
Re: USB extension from motherboard?
Donnerstag, 10. April 2008, 16:28
Just add a USB hub - works fine.
SpeedyGonzales
Donnerstag, 10. April 2008, 16:40
Hmmmmm....What kind of USB HUB has 5 "spear" connection as the motherboard have?
Do you have a link to your suggestion?
An ordinary USB HUB willl not fit the connectors!!
Speedy Out!
etoel
Freitag, 11. April 2008, 09:47
Look one page down and you'll find a post about internal USB hub, it got some good info.
Best of luck.
