• 11.04.2026, 12:40
SteinerKD
Cu/Twin-plex xt dimensions
Mittwoch, 25. Juni 2008, 21:04
What's the dimensions of these cooler? (it would be nice if dimensions for all colers was available).
Trying a mockup build in photoshop of a system and need correct dimension of parts to se what might fit.
BTW, any chanse this chipset cooler will work for a nf790i board?
SteinerKD
Re: Cu/Twin-plex xt dimensions
Freitag, 27. Juni 2008, 03:17
OK *blush*, feel a bit stupid now as I managed to find some of the numbers I was looking for ;)
Think, look THEN ask.
gr3if
Freitag, 27. Juni 2008, 11:58
For a 790i board you should use a Cuplex Cpu cooler with the right mounting kit.
SteinerKD
Samstag, 28. Juni 2008, 00:41
Now you confuse me a bit, are you saying that for a 790i mobo I should use a Cuplex CPU cooler for North/South-bridge?
