• 12.04.2026, 08:34
St4vr0s
Aquero Fan Output..5W Max??
Freitag, 18. Januar 2008, 02:21
Hi Guys,
Just got my hands on an aquero vfd but was wondering is there any way I can up the max limit on the fan output control?
It seems crazy to have only 5 watts per fan channel!
For example a tripple rad with some led fans was 7.2w This mean I have to split my tripple into 2 fans on channel 1 and then another on channel 2?
Problem I have here is that I'm building a tripple SLI config system with quad core etc etc but have like 13 fans on multiple rads.
Surely I dont have to have two aqueros?
Any suggestions?
Thanks
b0nez
Re: Aquero Fan Output..5W Max??
Freitag, 18. Januar 2008, 02:36
There are 2 Types of the Aquaero, a new (4.00) and an old (3.XX) one.
For the new one, 10W per Channel and 30W for all Channels is the miximum. The old one has a Limit of 5W per Channel and a total Limit of 15W for all 4.
Hope I could help you.
:rolleyes:
St4vr0s
Freitag, 18. Januar 2008, 14:39
hmmm,
Downloaded the manual off the website and it says 5watts per channel.
So its definately 10w per channel?
Thanks
Freitag, 18. Januar 2008, 15:14
As b0nez said ...
Stefan_K.
Freitag, 18. Januar 2008, 16:24
ask only in one forum please ;)
St4vr0s
Sonntag, 20. Januar 2008, 21:14
Thank you all.
@aqua-computer berlin. Just needed a swift response as the system was due to go to a press launch.
St4vr0s
Sonntag, 29. Juni 2008, 14:44
Hi guys,
Quick resurrection of this post ;)
How will this work if I connect a second flow sensor to the aquero via fan channel 4?
I currently have
7.2 watts on channel 1 (3x 0.2a Fans)
9.6 watts on channel 2 (4x 0.2a Fans)
8.64 watts on channel 3 (2x 0.2a Fans + 2x 0.16a fans)
Total=25.44 Watts
There is a flow sensor on the flow sensor channel.
With these things running will it allow me to use another flow sensor on fan channel 4?
Thanks
x-stars
Montag, 30. Juni 2008, 16:12
The power consumption of the flow sensor is minimal, so it's no problem :)
