• 14.04.2026, 00:13
Roman74Rus
Problems with Aquasuite in Russian Win Vista x86
Mittwoch, 17. September 2008, 10:02
Hello Aquacomputer.de crew!
I have terrible problem with aquasuite 4.63.00 or oldest.
In Russian Windows Vista x86 with your coolest pump AQUASTREAM XT Ultra version, i can`t manage and control pump, because i see window with bug report. Its says "The Arial font is not support "Regular" style, That bug report window shows when i try to find USB device or view report in aquasuite. I have Choise: 1.view more info 2. Try to proceed operation 3. Shut down aquasuite. When i try to proceed operation, nothing happens. Can you help me in this negative situation?
With best regards,
Roman Janssen, your Russian customer.
Re: Problems with Aquasuite in Russian Win Vista x
Mittwoch, 17. September 2008, 10:36
please copy and paste all detailed information from the message window here. We need this information for debugging.
Roman74Rus
Mittwoch, 17. September 2008, 19:01
The detailed information on use of the operative
(JIT) debuggings instead of given dialogue
Windows contains in the end of this message.
************** the exception Text **************
System. ArgumentException: the font "Arial" does not support style "Regular".
In System. Drawing. Font. CreateNativeFont ()
In System. Drawing. Font. Initialize (FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
In System. Drawing. Font. ctor (String familyName, Single emSize, FontStyle style, GraphicsUnit unit)
In AquaComputer. Graph. FontSpec. Remake (Single scaleFactor, Single size, Single and scaledSize, Font and font)
In AquaComputer. Graph. FontSpec. Init (String family, Single size, Color colour, Boolean isBold, Boolean isItalic, Boolean isUnderline, Color fillColor, Brush fillBrush, FillType fillType)
In AquaComputer. Graph. FontSpec. ctor (String family, Single size, Color colour, Boolean isBold, Boolean isItalic, Boolean isUnderline, Color fillColor, Brush fillBrush, FillType fillType)
In AquaComputer. Graph. Legend. ctor ()
In AquaComputer. Graph. PaneBase. ctor (String title, RectangleF paneRect)
In AquaComputer. Graph. MasterPane. ctor (String title, RectangleF paneRect)
In AquaComputer. Graph. ZedGraphControl. ctor ()
In AquaComputer. Forms.frm_data_analyze. InitializeComponent ()
In AquaComputer. Forms.frm_data_analyze. ctor (WindowCommunication and GlobData)
In AquaComputer. Forms.frm_Main.mnu_Trace_Activate (Object sender, EventArgs e)
In TD.SandBar. ToolbarItemBase. OnActivate ()
In TD.SandBar. ButtonItemBase. OnActivate ()
In TD.SandBar.xf92605a24a69622a.x0ef5a9135fb0040c (TopLevelMenuItemBase xccb63ca5f63dc470, Boolean x674341222c6bbaba, Boolean x37b4525011735d95, Point x13d4cb8d1bd20347)
In TD.SandBar. TopLevelMenuItemBase. Show (Boolean select)
In TD.SandBar. TopLevelMenuItemBase. Show ()
In TD.SandBar. ToolBar. OnItemPush (ToolbarItemBase item, Point position)
In TD.SandBar. ToolBar. OnMouseDown (MouseEventArgs e)
In TD.SandBar. MenuBar. OnMouseDown (MouseEventArgs e)
In System. Windows. Forms. Control. WmMouseDown (Message and m, MouseButtons button, Int32 clicks)
In System. Windows. Forms. Control. WndProc (Message and m)
In TD.SandBar. ToolBar. WndProc (Message and m)
In System. Windows. Forms. Control. ControlNativeWindow. OnMessage (Message and m)
In System. Windows. Forms. Control. ControlNativeWindow. WndProc (Message and m)
In System. Windows. Forms. NativeWindow. Callback (IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Roman74Rus
Mittwoch, 17. September 2008, 19:02
(Part 2)
************** the Loaded assemblages **************
mscorlib
The assemblage version: 2.0.0.0
Version Win32: 2.0.50727.1434 (REDBITS.050727-1400)
CodeBase: file:///C:/Windows/Microsoft. NET/Framework/v2.0.50727/mscorlib.dll
aquasuite
The assemblage version: 4.63.3167.15566
Version Win32: 4.63.00
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/aquasuite.exe
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0 __ b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System. Windows. Forms/2.0.0.0 __ b77a5c561934e089/System. Windows. Forms.dll
System. Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System. Drawing/2.0.0.0 __ b03f5f7f11d50a3a/System. Drawing.dll
WindowCommunication
The assemblage version: 1.0.3167.15562
Version Win32: 1.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowCommunication. DLL
Database
The assemblage version: 2.0.3167.15562
Version Win32: 2.0.3167.15562
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/Database. DLL
USB
The assemblage version: 2.0.3098.23103
Version Win32: 2.0.3098.23103
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/USB.DLL
WindowDialog
Version Win32: 1.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowDialog. DLL
SandBar
The assemblage version: 1.4.2.1
Version Win32: 1.4.2.1
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/SandBar. DLL
System. Deployment
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System. Deployment/2.0.0.0 __ b03f5f7f11d50a3a/System. Deployment.dll
System. Deployment.resources
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System. Deployment.resources/2.0.0.0_ru_b03f5f7f11d50a3a/System. Deployment.resources.dll
Interop. JRO
The assemblage version: 2.6.0.0
Version Win32: 2.6.0.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/Interop. JRO.DLL
mscorlib.resources
System. Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System. Data/2.0.0.0 __ b77a5c561934e089/System. Data.dll
System. Transactions
CodeBase: file:///C:/Windows/assembly/GAC_32/System. Transactions/2.0.0.0 __ b77a5c561934e089/System. Transactions.dll
System. EnterpriseServices
CodeBase: file:///C:/Windows/assembly/GAC_32/System. EnterpriseServices/2.0.0.0 __ b03f5f7f11d50a3a/System. EnterpriseServices.dll
System. Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System. Configuration/2.0.0.0 __ b03f5f7f11d50a3a/System. Configuration.dll
System. Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System. Xml/2.0.0.0 __ b77a5c561934e089/System. Xml.dll
myTranslationClasses
The assemblage version: 2.50.3152.29927
Version Win32: 2.50.3152.29927
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/myTranslationClasses. DLL
Roman74Rus
Mittwoch, 17. September 2008, 19:03
(Part 3)
WindowTubemeter
The assemblage version: 2.0.3167.15564
Version Win32: 2.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowTubemeter. DLL
WindowMultiswitch
The assemblage version: 2.0.3167.15566
Version Win32: 2.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowMultiswitch. DLL
WindowAquaero
The assemblage version: 2.0.3167.15563
Version Win32: 2.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowAquaero. DLL
WindowAquaduct
The assemblage version: 2.0.3167.15565
Version Win32: 2.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowAquaduct. DLL
WindowPoweradjust
Version Win32: 1.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowPoweradjust. DLL
WindowAquastream
Version Win32: 2.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowAquastream. DLL
WindowAquaduct240Pro
Version Win32: 2.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowAquaduct240Pro. DLL
WindowAquaduct360mk2
Version Win32: 2.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowAquaduct360mk2.DLL
ControlLibrary
The assemblage version: 2.1.3098.23104
Version Win32: 2.1.3098.23104
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/ControlLibrary. DLL
_wnco0_2
yfgslhmj
WindowDataAnalyze
Version Win32: 2.0
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowDataAnalyze. DLL
SandDock
The assemblage version: 2.4.3.1
Version Win32: 2.4.3.1
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/SandDock. DLL
AquaComputer. Graph
The assemblage version: 5.0.3.22353
Version Win32: 5.0.3.22353
CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/AquaComputer. Graph. DLL
System. Drawing.resources
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System. Drawing.resources/2.0.0.0_ru_b03f5f7f11d50a3a/System. Drawing.resources.dll
System. Windows. Forms.resources
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System. Windows. Forms.resources/2.0.0.0_ru_b77a5c561934e089/System. Windows. Forms.resources.dll
************** Operative debugging (JIT) **************
For connection operative (JIT) debuggings a file.config data
The application or the computer (machine.config) should have
Value jitDebugging, established in section system.windows.forms.
The application also should be compiled with switched on
Debugging.
For example:
<configuration>
<system.windows.forms jitDebugging = "true"/>
</configuration>
At switched on debugging JIT any not processed exception
It is sent debugger JIT registered on the given computer,
Instead of being processed by the given dialog box.
Roman74Rus
Samstag, 20. September 2008, 04:33
Zitat von »Shoggy«
The aquasuite can be switched to english.
You can also add a new language by yourself. Check the folder aquasuite\database. There you will find a MS Access database called aquasuite.mdb. It contains all the text strings and you can add a new language.
As i can see, now this info is not actual  ??? If you give me a few instructions where i can find language files now (huh... database.dll, right? ), i can make Russian language for aquasuite  ;) Besides, it help me to kill a some time before new version of aquasuite is accessible for to downloading)))
Sonntag, 21. September 2008, 21:13
hi,
the file "aquasuite.mdb" is not in the application folder.
The file is in the common-applicatiions folder (use the windows search function to find it).
In the next aquasuite version we fix your probelm.
Montag, 22. September 2008, 12:27
hi,
This problem seems to occur if the Arial font is corrupted or missing on your system.
Install or reinstall the arial font in your System.
Roman74Rus
Dienstag, 23. September 2008, 02:47
Eah! You were right! I have added and reinstalled my font "Arial" and his variations. Now aquasuite is work! Yeeehaa!
Thank you very much for your supporting and help!  :) AC Team - is the best! :D
Ok, within some time i will make ru_lang for aquasuite! )))
P.S. WoW! I dont know all about german engineering, but now i can easily tell: nothing beats german programming )))) Possibilities of aquasuite is deep inpress me))) Now i sure will buy other your devices)))
