• 02.01.2026, 15:56
drbo
Cuplex HD vs. XT di?
Dienstag, 21. Oktober 2008, 14:58
Hi, I have a question.
I have both the Cuplex Xt di and the new Cuplex HD (in order).
Since I am now rebuilding my two systems, I am wondering which of these blocks that will perform best on an OC qx9650, that runs pretty HOT. OK I know this also depends an the radiators, but I have sufficient radiator power (single+dual+triple) in my rig. 8)
So, does AC or others have a flow vs cooling performance graph or something? Or at least an indication at which speed the the HD out performs the XT di. Or will the Xt di always be better, but with a higher flow resistance?
I am grateful for all answers and discussions on this topic. :)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
Re: Cuplex HD vs. XT di?
Dienstag, 21. Oktober 2008, 15:03
Have a look on this cooler roundup: Dexgo.com CPU Watercooler Roundup (Google Translation)
drbo
Dienstag, 21. Oktober 2008, 22:51
Thanks shoggy.
This answered all my questions. (And I axctually preferred the german version. I read german quite well, although I dont write).
But the conclution is that the HD always will perform better than the Xt di, which leads to another question. Are you planning a HD version of the chipset cooler?
Thus the only reason for choosing the more expensive Xt di is the fantastic look! 8)
