• 23.02.2026, 02:22
Kermit
aquadrive
Mittwoch, 8. Dezember 2004, 20:38
I have received my kit (thx Stephan,-- I am stephane from London)
IT seems that I don't have the mounts for the aquadrive.
How to fit it?
Stephane
Stefan_K.
Re: aquadrive
Mittwoch, 8. Dezember 2004, 21:16
Hi Stephane ..
they are normally inside the drive when delivered. Otherwise drop me a mail then i add them to the next order.
Regards
Stefan
Kermit
Re: aquadrive
Mittwoch, 8. Dezember 2004, 22:25
Stephan,
I have just droped you an email, you might need to send me the parts before I place the other order.
The other order will be after Xmas, and I wont be able to wait until then to get my system up and running ::)
Stephane
