• 26.03.2026, 22:58
Anon5710
aquabay / aquastream
Donnerstag, 16. Dezember 2004, 20:43
If the aquatube is installed in the aquabay, is it possibel to place the aquastream also on to the aquabay?
This is simething i didn't quite understand.
kampfsau
Re: aquabay / aquastream
Donnerstag, 16. Dezember 2004, 20:56
there´s only one answer to your question:
YES! ;D
NikoMo
NikoMod
Donnerstag, 16. Dezember 2004, 21:35
yes, it's possible to install the AS together with an AT in the aquabay.
but it's not possible to install it in the FMJ
Anon5710
Freitag, 17. Dezember 2004, 13:06
thats verry nice to know :-)
But what is FMJ ?
Freitag, 17. Dezember 2004, 14:08
FMJ = Full Metall Jacket ;D
It's used to insulate the harddisk from magnetic radiation.
fabelmann
Freitag, 17. Dezember 2004, 18:32
but, I prefer to install the AS on the floor of the case. it is easier to fill your system. when you installed your pump in the aquabay, in my opinion (and experiences) it is hard to get the water out of the aquabay into the AS, even if you installed some angles.
Anon5710
Samstag, 18. Dezember 2004, 18:15
yes but i will get 2 of such reservoirs ;) one in top of my case, i can fill it there much easyer ;)
fabelmann
Samstag, 18. Dezember 2004, 18:17
well, then it is equal
Beun
Samstag, 18. Dezember 2004, 23:45
of topic: do you guys think a FMJ is really nescesarry?
crushcoder
Sonntag, 19. Dezember 2004, 00:02
no, unless you have problems with your monitor (happens sometimes if the pump is near to the monitor).
or if you feel uncomfortable because of a theoretical possibility.
there is no evidence that problems with harddisks were caused by the pump.
Nitrix
Sonntag, 19. Dezember 2004, 00:42
I have my pump under my hard drive with no fmj :o but it works fine ;D
W03lfch3n
Sonntag, 26. Dezember 2004, 14:54
Yeah thats really true. it was much easier to fill the system when it still was on my pc's floor. but well, in my opinion it looks much more tidy in the aquabay :)
btw, i dont use an FJM as well, works fine for me, no problems ever.
FarEast
Samstag, 15. Januar 2005, 14:15
well if your going for the tidy but easy to fill route you could do what i did:
