• 11.11.2025, 06:45
damado
Fan rpm not showing in aquero
Freitag, 11. Februar 2005, 05:25
Everything seems to be working fine except I canno see the fan speed....sometimes when I move the %, it shows for a second then goes away.
Re: Fan rpm not showing in aquero
Freitag, 11. Februar 2005, 13:26
Which type of fans are you using?
What rpm is showed for that second?
damado
Samstag, 12. Februar 2005, 02:31
One is a sunon and one is a panaflow. For the split second that is sometimes shows, its 2470 or so.
