• 24.01.2026, 01:04
modsquad
Cuplex XT
Sonntag, 6. März 2005, 10:08
I just ran across the new cuplex XT
Do you have a release date for these units or are they just prototypes?
Beun
Re: Cuplex XT
Sonntag, 6. März 2005, 11:52
I think it will be released in several weeks.
Off topic: Will there also be a chipset version?
saUerkraut
Re: Cuplex XT
Sonntag, 6. März 2005, 11:57
A Chipset Version was also developed...but they (AC) arent sure if they should release it! ;)
Nitrix
Re: Cuplex XT
Sonntag, 6. März 2005, 13:17
As for release dat id say a week or two tops ;)
r1ppch3n
Re: Cuplex XT
Sonntag, 6. März 2005, 15:29
make that months and you're getting closer :-X ;D
not that i'd know any more than you but as long as there's no official release date... ;)
or to put it this way: it's done when it's done
Nitrix
Re: Cuplex XT
Sonntag, 6. März 2005, 16:01
it will be closer tbh as there are sites that have them on pre order the figure ive heard is 10 days
Beun
Re: Cuplex XT
Sonntag, 6. März 2005, 17:22
huh why??
propurple
Re: Cuplex XT
Montag, 7. März 2005, 05:41
have they developed for xeons yet ? worth waiting on my order offcuplex rev 1.3 or should i just go ahead and get what im already getting?
Re: Cuplex XT
Montag, 7. März 2005, 07:42
to use two of thes coolers in one cooling-system is not a good idea. This kind of coolers have a very high resistence so you maybe need a bigger pump (? Pumpe ?).
So for dual solutions the CuPlex Classic is quiet bettet...
Man In Blue
Stefan_K.
Re: Cuplex XT
Montag, 7. März 2005, 11:56
believe me they are joking
THEdude
Re: Cuplex XT
Freitag, 11. März 2005, 22:38
Anyone spotted a review already? :)
Re: Cuplex XT
Sonntag, 13. März 2005, 13:51
The cuplex xt is available beginning of next week. You can preorder the xt in our onlineshop or at your dealer. Delivery will start next week.
Top_Nurse
Re: Cuplex XT
Mittwoch, 16. März 2005, 22:38
So how much resistance to flow can we expect on the Cuplex XT? Considering all those tiny holes I would expect quite a bit. Would it be better to use just one parallel line to go from the CPU back to the reservoir?
