• 19.11.2026, 12:37
Top_Nurse
Re: 1/2" Barb Moded Aquatube and AquaZilla
Mittwoch, 13. April 2005, 03:33
Very nice! Did you keep the center back G 1/8 for the Aquatube?
Mysticcal
Samstag, 16. April 2005, 09:44
Just wanted to let you know that it's brass that oxidized very quickly or even longly in some extreme cases, copper doesn't oxidize unless unkept for years, it's a very powerful metal in cooling and so is aluminum in heat retention while copper is best for dissapation. I'm sure AC needs to change their manual, and also, not ALL manuals are correct.
friku
Sonntag, 17. April 2005, 21:08
Top_Nurse:
I´ve kept the center back, and first of each side G1/8". They are for the led and temp. sensor.
Cheers,
friku.
