• 22.02.2026, 00:28
Timstone
Material thickness
Donnerstag, 28. April 2005, 19:29
Hi all,
I have aquestion about the thickness of the frontpanel for the Aquabay.
What is the thickness of the material used for this frontpanel (art. nr. 93097)?
Men may control the free world, but women control the boobs. Brent in Player vs. Player
Mr_modnaR
Re: Material thickness
Donnerstag, 28. April 2005, 22:02
It's 2mm thick
Timstone
Freitag, 29. April 2005, 13:55
Thanks for the answer.
I saw that measurement mentioned with the other frontpanel, but I wasn't sure if it applied to this frontpanel as well.
Ah well, thank you!
Mr_modnaR
Freitag, 29. April 2005, 16:55
sorry i thought you meant the original panel, which is stainless steel, i'm not sure about the aluminium one, though i would have thought it'd be the same. it definately wouldn't be any thinner than 2mm, cos aluminium isn't as strong as steel. ;D hope this helps
