• 23.02.2026, 14:13
Sathy
twinplex cs-block and DFI LP UT NF4 SLI-D
Montag, 16. Mai 2005, 21:33
I was wondering, does anyone know if the twinplex rev. 1.2 Chipset block fits the DFI Lanparty UT NF4 SLI-D fitted with two graphics cards? if not, does anyone know any watercooling solution that would fit? Thx in advance
Damn, not knowing german and trying to figure out which button does what is a wee-bit hard...well I guess I've made it now =]
.Sathy
edboswell
Re: twinplex cs-block and DFI LP UT NF4 SLI-D
Montag, 16. Mai 2005, 21:37
i have this but no it doesn't fit you have to use a koolance one - google it
NikoMo
NikoMod
Montag, 16. Mai 2005, 22:54
there is no cooler that fits at the dfi-board.
their own air-cooler doesnt fit, if you want to install a pcie-graphics card in the upper slot.
it is a pitty, but the fan scratches along the graphiccard-pcb.
Mr_modnaR
Montag, 16. Mai 2005, 23:20
can't understand why anyone would do this!
it's like making a car, and then saying "oh you want a driver and a passenger? no i am afraid you can't do that: they won't fit!"
Sathy
What a pity yes. Thanks for the quick answer anyway, have to figure out something else then.
Top_Nurse
Dienstag, 17. Mai 2005, 04:35
I believe there is this rumor going around that A-C will be releasing for sale soon a Twinplex made specifically for SLI boards. It is reputed to be considerably thinner than the standard Twinplex and has a different cooling design.
edboswell
Dienstag, 17. Mai 2005, 10:07
yay ;D ;D ;D ;D
