• 13.05.2026, 01:47
f4brice
Fan not set to 100% power by Aquaero ?
Sonntag, 22. Mai 2005, 18:24
Hi all.
I'm surprised to see that my Aquaero does not set one fan to 100% power when the corresponding temperature sensor has reached its max limit.
My config :
- Aquaero 4 running OS 2.03, firmware 4.05
- Aquasuite 1.0.1958.14139 (1.0 bete 4)
I think there's something bad in my settings, but I can't find where...
I did some snapshots of my settings :
Sensor settings :
Fan settings :
Overview :
In this last snapshot, one can see that the water's flow is wrongly reported. I need to do some investigations...
Regards.
Stefan_K.
Re: Fan not set to 100% power by Aquaero ?
Sonntag, 22. Mai 2005, 19:34
It´s a known bug. Will be fixed in the next Rev. of the aquasuite. ;)
x-stars
Sonntag, 22. Mai 2005, 21:53
Yeah - fixed in the next version which will probably released next week.
Edit:
If you need a workaround: Set the fans to 99% (aquasuite) or set them manually by the aquaero-menu to 100% :D.
