• 11.04.2026, 00:16
edboswell
2 pumps?
Donnerstag, 2. Juni 2005, 21:08
Iv currently got what i would consider quite a big set up... 1800 rad. cpu, gfx (*2 in future), northbridge, res. and near future - 360 rad., psu water cooled and hdd cooler... now i have a 1068 ehiem pump does anyone think its worth getting another one... from my Visual Flow Wheel the water does not seem to be going around thattt fast but in the future with my set up would it be worth getting another pump... or is it not worth it?
Mr_modnaR
Re: 2 pumps?
Donnerstag, 2. Juni 2005, 22:59
with an 1800, i think you can cool something like 40 CPUs!!! i'm sure you won't need an extra rad! if you're getting high temps anywhere, there's obviously something else wrong.
not sure you should be judging your flow rate with one of those visual flow wheels, you're better off getting a flow sensor from AC, that way you can make an accurate judgement as to whether or not you need an extra pump!
edboswell
Re: 2 pumps?
Freitag, 3. Juni 2005, 00:00
hehe yer i know, im getting good temps:P but i just need the 360 for lans... incase i need to take the 1800 off (i wouldn't want my beauty damaged 8)
+ ok yer sure
Mr_modnaR
Re: 2 pumps?
Freitag, 3. Juni 2005, 01:41
aah! i see now
