• 03.04.2026, 06:12
edboswell
warrenty invalid?
Mittwoch, 8. Juni 2005, 12:47
Right my motherboard is broken ;D yay it can't reackonise the ram... already rma'd the ram and got a £20 bill for it being non faulty :-[ anyway does water cooling invalid the warrenty for my motherboard at all (dfi nf4 sli)? Just checking so i can get rid of any trace of evidence that i have used water cooling if it does....Thanks
Mr_modnaR
Re: warrenty invalid?
Mittwoch, 8. Juni 2005, 16:35
I think it does. :'(
To make sure you're ok, just return it as you bought it. ;D
edboswell
Mittwoch, 8. Juni 2005, 17:05
ok :-[ nevermind some more watercooling stuff came in the post just then so thats made me feel better ;D
J_Tuvix
Mittwoch, 15. Juni 2005, 19:40
well, if you did not have watercooling for the nvidia nforce chip then you probably only lost the warranty for your cpu, not the mainboard
and the problem with the ram:
the dfi lanparty nf4 has serious problems with some ram types. the ram could really be ok an working in other pcs
Katzenfreund
Mittwoch, 15. Juni 2005, 20:47
afaik you also lose the warentry of your Maiboard even if you just cool your CPU. Because the Powertransformator (in German: Spannungswandler) need to be cooled be air or with a passiv cooler.
J_Tuvix
Donnerstag, 16. Juni 2005, 18:23
but i haven't seen any mainboard which says specifically in the manual that it needs aircooling on the cpu so that the mainboard is cooled.
edboswell
Donnerstag, 16. Juni 2005, 18:43
well its sent back now ill see what they say (whether they have noticed that it has had watercooling on it or not)
Ed
