• 25.03.2026, 23:28
Ze@lot
a few small questions
Mittwoch, 31. August 2005, 21:48
im bored waiting for some bits to come
looking at the german section even though my google
translator dont work on AC websites  :-/
1. on my AquagraFX 6800 cooler i noticed a little treaded
hole in between the inlet & outlet. is there a bracket that im
missing like this one maybe ?
2. what will the aquabus do ? and is the somewhere special
is should go ? does the hole layout mean its proberly not
able to be mount to my aquaero ??
Re: a few small questions
Mittwoch, 31. August 2005, 22:04
The second picture is a very early version of the Multiswitch - just forget this version. It has changed a lot :)
The Aquabus is the communication protocol to add extensions like the Multiswitch.
Ze@lot
Donnerstag, 1. September 2005, 01:29
lol thanks shoggy for clearing that up ;D
3. whats a multiswitch do ? , where would i mount it i.e. does it need a clear drivebay ?? & have you any up to date piccies ?? ?
hope that delivery gets here soon ;)
pharao
Donnerstag, 1. September 2005, 03:50
yes.
unless there's a lite version (like the aquaero lite), but I don't know ;)
Stefan_K.
Donnerstag, 1. September 2005, 18:33
no,
there will be a lite version. ;)
Top_Nurse
Freitag, 2. September 2005, 12:29
Zitat von »Ze@lot«
...whats a multiswitch do ? , where would i mount it i.e. does it need a clear drivebay ?? & have you any up to date piccies?
AFAIK no one (that's talking anyway) has updated pics or prices. Although I seem to recall something in the neighborhood of like 60-70 Euro for the version that needs a 5.25" drive bay and like 40 Euro for the version that doesn't need a drive bay. Expect that to change :-/ I believe the drive bay unit has like 5 or 6 switches on it and the other one has only software selectable switches. As far as I can discern the Multi-Switch will allow you to control any device up to 12 Vdc and utilize the Aqua Suite interface to institute a custom set of parameters as to what does what when.
Ze@lot
Montag, 5. September 2005, 22:12
thanks TN ;D
