• 04.04.2026, 03:52
edboswell
360 grills on 1800
Donnerstag, 22. September 2005, 20:25
hi might sound a bit stupid but ill say it anyway... can you fit the 360 grils onto the 1800... do you need the fans in place or can you just put them striaght onto the rad. also is it possible to get the Aqua steel bezel for Airplex EVO 360 in black thanks
Ed
Mr_modnaR
Re: 360 grills on 1800
Donnerstag, 22. September 2005, 20:49
short answer: yes, no fans needed and no!
