• 22.02.2026, 04:03
Sc4mpi
Aquero aquastream query :)
Mittwoch, 5. Oktober 2005, 14:56
hello all , well after leerking for a while, i though i better get into the action :)
anyways iv been using innovatek cooling for the last couple of years but now iv invested in some aquacomputer blocks mainly a aquero 2 aquastreams and ramplexs etc.
my query was how do u run two pumps off the aquero? iv made the cable. and in the software it states u can have 2
but i was wondering how exactly you set the pump to 1 and 2, ?
Re: Aquero aquastream query :)
Mittwoch, 5. Oktober 2005, 16:18
You will have to change the id-number of one pump with the adress-jumper:
Sc4mpi
Mittwoch, 5. Oktober 2005, 16:29
thanks i had a feeling it was that but i wasnt entirly sure, thanks for the clarification. 8)
DerrickD
Donnerstag, 6. Oktober 2005, 02:31
shoggy can i get a pic like this of the back of the aquero that lists all the pins and headers
Donnerstag, 6. Oktober 2005, 02:35
DerrickD
Freitag, 7. Oktober 2005, 01:57
Zitat von »Shoggy«
thank you so much
DerrickD
Freitag, 7. Oktober 2005, 08:50
Zitat von »DerrickD«
thank you so much
im getting eeprom error?
