• 14.04.2026, 02:49
SNTmods
Aquatube Copper Special Edition
Donnerstag, 27. Januar 2005, 00:21
I am very interested in getting one of these Special Edition Aquatubes. Is it still available and if so, at what cost? My distributor doesnt have any pricing on it.
-Dan
SNTsystems
Was an early adopter of Aqua-Computer watercooling in the U.S.
Re: Aquatube Copper Special Edition
Donnerstag, 27. Januar 2005, 00:29
It's isn't available and will not be produced again because there were several problems...
For example: the tool-head(?) broken off several times :-/
damado
Montag, 7. Februar 2005, 23:07
-Dan
SNTsystems
Is there a link to a picture of this?
Dienstag, 8. Februar 2005, 00:11
SNTmods
Dienstag, 8. Februar 2005, 04:43
It is very attractive, too bad I wont be able to get one for my next display computer. :p
-Dan
ThaDog
Mittwoch, 9. Februar 2005, 04:31
A.. The CopperTube........
My Precious ;D ;)
http://forum.aqua-computer.de/index.php?…&threadID=85668
mfg,
ThaDog
Top_Nurse
Dienstag, 31. Mai 2005, 10:48
Please don't shoot me for ressurecting this old thread. :-X
You say the tool head broke off several times? Copper is difficult to machine with normal tools because it tends to be gummy. It takes a certain rake or cutting angle of the tool to work properly. Standard indexable insert technology generally doesn't work well because the material builds up on the tool point and breaks the tool. So if this was the problem then would you be willing to produce this again if the right tooling was available?
x-stars
Dienstag, 31. Mai 2005, 16:22
I don't know if this really was the problem, but how is it, the there aren't problems with the copper while producing Cuplexs/Twinplexs - they're made out of a copper-block, too ::).
Top_Nurse
Dienstag, 31. Mai 2005, 23:05
Milling is a different issue due to tool clearance allowing the chips to get out of the way. Turning tools, especially ID boring operations, get tricky because the tool is in the cut continously till the machine moves out of the cut. An end or face mill only cuts a few .001" per tooth and moves in and out of the cut very fast.
Mr_modnaR
Mittwoch, 1. Juni 2005, 01:03
couldn't they cast the basic shape, and then finish it off on the lathe? that way the tool would have to do less work.
Top_Nurse
Mittwoch, 1. Juni 2005, 09:53
Sounds expensive
Mr_modnaR
Mittwoch, 1. Juni 2005, 16:42
true, but i'm sure they could contract the casting to a professional foundry, and do it as a large batch, thus keeping costs down!
i'm sure there's lot of people who would pay a little extra for one of these Aquatubes! ;)
Infiltraitor
Mittwoch, 1. Juni 2005, 17:29
I don't know how pure the 'high purity 99.9%' copper that AC use is but from here-
Pure copper is extremely difficult to cast as well as being prone to surface cracking, porosity problems, and to the formation of internal cavities.
I suspect the casting process alone might push the price of these above what most are prepared to pay, if you factor in the price increase due to the probable amount of failures and reworks due to casting problems, the whole thing is likely to be a non-starter.
Mr_modnaR
Mittwoch, 1. Juni 2005, 21:00
oh well, nevermind. :(
guess some'll turn up on ebay at some point! ;D
Infiltraitor
Mittwoch, 1. Juni 2005, 23:01
I'd put a little side bet on one fetching more than it cost new if one ever does turn up for auction. ;D
Mr_modnaR
Donnerstag, 2. Juni 2005, 01:50
ok, and if you win, you can use that money to buy me it, deal? ;D
Infiltraitor
Donnerstag, 2. Juni 2005, 02:25
Erm... ???
I'll tell you what. If one does come up for auction, I'll stop bidding on it once it goes past what is cost new.
Then you're golden ;D
Top_Nurse
Montag, 17. Oktober 2005, 11:24
You know something we don't know?
Stefan_K.
Montag, 17. Oktober 2005, 12:21
No mining for copper topics here.
Just let old topics disappear if nothing important happens.
Closed
Stefan
