• 10.01.2026, 09:37
MUFFDIVER
Project begins, will it all fit?
Dienstag, 8. November 2005, 23:07
ok here is my project which im starting tomorrow.
heres the kit list. (ignore my abbreviations)
2 x pumps
2 x ram coolers
1 x Cooler for voltage regulator
1 x cuplex pro rev.2
1 x 6600gt aquagfx pciE
2 x aquatube rev1.1
1 x twinplex rev1.2
1 x 360 rad
1 x 240 rad
1 x 120 rad
all to go in a Cm-Stacker
no monitor as yet but will add later
and also here is my system spec. will a revoltec chromus 500watt run
2 x pumps
A8n sli deluxe mobo
2 x hdds
1 x dvd burner
5 x 120mm fans
2 x 80mm fans
2 x 6600gt pci-e gfx cards.
1 x 3200 AMD64
1 x 1GB corsair ram
2 x UV cathodes
will the power supply handle all of that?
Cheers.
ps. will update with pics.
Ze@lot
Re: Project begins, will it all fit?
Mittwoch, 9. November 2005, 20:03
nice 1, i look forward to seeing some pics.
