• 22.02.2026, 00:25
MUFFDIVER
aquaero q?
Donnerstag, 24. November 2005, 19:11
ok if i was to buy one and a multiswitch i want to buy the whole package ie. make full use of it. So what would be a full package ie tubemeters etc.
1) Why does aquacomputer not do a full package deal for this?
2) What is the full details for all that can be used with the aquaero and multiswitch?
THANKYOU...
Top_Nurse
Re: aquaero q?
Donnerstag, 24. November 2005, 20:33
Full package = Aquaero, Multiswitch, and enough Tubemeters to put in each Aquatube. They don't do a package as this stuff is highly individualized and no one would need both a Multiswitch or an Aquaero. BTW, you can run a Multiswitch without an Aquaero.
There are no full details as their really isn't a manual other than how to hook it up and that is in German. If you hook it up and turn on the Aquasuite software it should be readily apparent as to what you can and can't do. There are more can's than can'ts ;D
