• 22.02.2026, 00:26
raz6000
AQUA BAY PUMP AND RES MOUNT
Freitag, 9. Dezember 2005, 10:34
Can sombody tell me the dimensions of the Aquabay res and pump mount?
A few pics would be really good 2!! including the bottom...
Cheers,
Ray
Top_Nurse
Re: AQUA BAY PUMP AND RES MOUNT
Freitag, 9. Dezember 2005, 21:46
Well it should be obvious that it takes up two 5 1/4" slots correct?
raz6000
Samstag, 10. Dezember 2005, 04:43
Hey,
Thanks for the pics very useful..
Sorry to sound such a dumbarse!!!
Just wanted to get a better idea of the setup, i'm planning to custom build a case to fit around the aquabay for the pumb, res, controller and the 360 rad on top...
should be Vsweet once finished!
The idea is to have the main CPU case connected to a small aquabay cooling tower case.
Thanks for the help so far..
What do ppl think of the MCubed T-Balancer XL?? I know I does not have the LCD like the aquaro but it does the same job in the long run once you have got the bits. I like the idea that you can spread the payments and have the same setup in the end..? Are there any downfalls????
Cheers,
Ray
pharao
Samstag, 10. Dezember 2005, 09:28
Cheers,
Ray
this is a manufacturers forum, so please don't discuss about other products.
There are independent forums for that.
greets
hobbes
MUFFDIVER
Sonntag, 11. Dezember 2005, 23:32
yet again i think this is starting to warrant an off topic forum as we get slapped for posting inapropiate text. He was just asking a question and believe it or not after you guys helping him he was just trying to pick your brains some more.
So where does he post this question then?
raz6000
Montag, 12. Dezember 2005, 00:23
Sorry was a bit cheeky... Just seems to be a good group here!
Any other good forums recomeded? (NOT TRYING TO LEAVE THIS ONE)
Cheers,
Ray
Montag, 12. Dezember 2005, 01:13
And even in an off topic section he could not ask this because it will not change the fact that this forum is a manufacturers forum.
There are a lot of independent forums like hardforum.com for example.
MUFFDIVER
Montag, 12. Dezember 2005, 01:22
hmm ok then....... ??? ??? ??? ??? ??? ???
So AC's version of Offtopic doesnt mean offtopic then.
Montag, 12. Dezember 2005, 01:28
Why is that so hard to understand? AC has its own products and wants to sell them. If he had asked for something which AC does not offer everything would be fine. But AC has its own product: the aquaero LT. So there is no place for other products.
pharao
Montag, 12. Dezember 2005, 12:31
Cheers,
Ray
maybe the hardforum? personally, i don't surf other english hardware-forums that often, but Top_Nurse seems to know that forum and Chewy usually posts his mods there...
