• 22.02.2026, 00:24
Isaksson
Order - fast answer if possible
Dienstag, 20. Dezember 2005, 09:16
Hello.
i was just ready to send my order but when it came to
payment then the only thing that i could use was "money order"
but i dont know what that is, i live in sweden.
Could someone tell me what a "money order" is
and how aquacomputer get my money?
thanks
Isaksson
Re: Order - fast answer if possible
Dienstag, 20. Dezember 2005, 09:38
Is it that i pay to aquacomputers bankaccount beffore they send my order?
Nitrix
Dienstag, 20. Dezember 2005, 10:27
it means you have to transfer/wire the cash directly into there bank account.
once this has cleared they will dispatch your order.
Isaksson
Dienstag, 20. Dezember 2005, 10:38
Okey,
thanks for the answer,
i continued with the order now ian then i saw this
Make Payable To: Aqua Computer, Commerzbank Göttingen, BLZ 26040030, Konto-Nr. 6409486, IBAN DE28 2604 0030 0640 9486 00, SWIFT COBADEFF260
Send To:
May & Wille, Aqua Computer Systeme GbR
Gelliehäuser Str. 1
37130 Gleichen
+49 5508-9749-131
So i have to send a mail to them?
or is it possible to just transfer money to ther bankaccount
from my bankaccount?
have someone tryed that? or do i have to mail them the money?
x-stars
Dienstag, 20. Dezember 2005, 12:38
Zitat von »Isaksson«
Okey,
Send To:
Gelliehäuser Str. 1
37130 Gleichen
+49 5508-9749-131
No, ypu don't mail the the money, the money is transferred by your bank to AC's bank. The IBAN/SWIFT-Codes are neccasary for transfers in Europe, so you can safe "transfer taxes" (the money, the bank usually gets for international transfers). Just go to your bank, ask for an transfer-paper for inner-Europe-transfers and they should help you with this (otherwise you should change your bank ;D).
Isaksson
Dienstag, 20. Dezember 2005, 12:49
Thanks for the answer.
i logged in on my bank and checked and there should not be any problem, i just added aquacomputer so iam ready to transfer the money.
Thanks again,
soon i will have a Aqua"computer" 8)
MUFFDIVER
Mittwoch, 21. Dezember 2005, 21:14
ahh the joys of that first post arivening its like getting a puppy and looking into its eyes for the first time, then the little git decides to leak all over the place (Graphics card).
But when it all comes threw the post take your time and enjoy doing it, Dont rush as i did the first time and made a few mistakes.
And post sum pics when you are done.
Isaksson
Donnerstag, 22. Dezember 2005, 01:49
Yes, i will post some pic´s when iam done,
and you have right, better to think twice beffore you rush in to it.
And if i have any problem i will let you know ;D
Merry Christmas
Fröhliche Weihnachten
