• 22.02.2026, 00:25
KingOfTheCircle
Radiator HTF3
Montag, 19. Dezember 2005, 12:26
Hello,
I am new to WC and I am looking for a good system. A while ago I found AC on the internet and now I have decided that I want to implement their system. In my computer, that I use for experimenting, is not enough room to install an Airplex 120. However there is probably enough room for Radiator HTF3 Single 80 [31062], but I couldn't find the dimensions on the AC website. Can someone tell me what they are? And is it possible to put one after another with just 1 fan?
TIA!
jcab
Re: Radiator HTF3
Donnerstag, 22. Dezember 2005, 11:55
The radiator dimensions are: 123 x 83 x 62mm (length x width x heigth)
