• 30.12.2025, 21:27
jackle
Need a little help
Dienstag, 20. Dezember 2005, 01:53
Hey up people im new here and i need a little help from you if you peeps dont mind?
Ok here is the story i have brought a 6600GT Aquacomputer Gfx card cooler thing and the person i got it off gave me some plug n play clip things at a 45degreee angle but unforunatly they dont fit my 1/2" tuing ::)
Anyway can someone tell me what fitting s i need to make it fit please/ i plan no buying the parts in january/feb when i sort out my whole loop :)
Nitrix
Re: Need a little help
Dienstag, 20. Dezember 2005, 10:26
you would need to get your self a barb to go to that width.
but i wouldnt really recommend using that gpu cooler in a 1/2" system as it would be a bottleneck and loose you alot of flow.
MUFFDIVER
Mittwoch, 21. Dezember 2005, 21:16
I agree!
jackle
Mittwoch, 4. Januar 2006, 18:53
but i have 1/2"tubing lol is there some kind of conferter i can get or something or am i best selling it on? I have enough 1/2"tubing for another machine and was going to use that :|
