• 22.02.2026, 03:56
edboswell
top - in, bottom - out? - XT cooler
Samstag, 7. Januar 2006, 17:17
does it matter which is the in and which is the out configeration for the xt 939 cpu cooler?
Re: top - in, bottom - out? - XT cooler
Samstag, 7. Januar 2006, 17:22
Yes, that matters.
On this picture the bottom is the inlet.
Ze@lot
Samstag, 7. Januar 2006, 17:23
yes it does matter, the inlet is the one that lead directly to the jets.
bahhh i wasnt quick enough, curse you shoggy ;D
edboswell
Samstag, 7. Januar 2006, 17:36
i presume that it is the same for the 939 version - the ac logo bottom right --> = bottom is the inlet?
Samstag, 7. Januar 2006, 17:50
You can't use the logo etc. for the direction beause you can exchange them :D It also doesn't matter which version you are using, the cooler itself is always the same.
edboswell
Samstag, 7. Januar 2006, 17:53
ooo ok thanks :)
