• 24.03.2026, 11:53
edboswell
aquaero fan problem
Samstag, 11. Februar 2006, 03:12
hi when my aquaero is trying to getting the water down to a certain temp the fans turn on then off... on for 3 seconds off for 0.5 seconds then again and again (about 15 times... until the temp has been restored to a stable matter).
is this normal?
thankz ed
MUFFDIVER
Re: aquaero fan problem
Samstag, 11. Februar 2006, 04:57
I dont have one but that doesnt sound normal, and from the video AC kindly made, there was no sign of them powering down. MB its a power issue? Maybe its broken :o
Dont know but hope this helped a little.
x-stars
Samstag, 11. Februar 2006, 23:47
On the temperature-sensor-tab in the aquasuite, theare are two options called "controller delay in sec." and "controller factor", try to set these values a little bit higher :D.
