• 29.01.2026, 19:01
Available: aquabox, aquagratiX, aquagraFX
Freitag, 17. März 2006, 19:51
The plexiglass version of the aquabox 5.25" is available right now. The version for the 3.5" slot should be available within the next 10 days.
*edit: Stephan also said they will produce a plexiglass version of the aquatube*
Price for the plexiglass aquabox 5.25": 52.90 Euro
The aquagratiX 850 has received a small update. It should fit all available cards without any problems. The older version had problems with a fan header and capacitors.
And finally two pictures from the aquagraFX 7800 512mb.
Top_Nurse
Re: Available: aquabox, aquagratiX, aquagraFX
Freitag, 17. März 2006, 21:18
Will the 7800 cooler fit the 7900 series cards?
Samstag, 18. März 2006, 20:34
As far as we know: Yes.
