• 09.01.2026, 23:18
new aquatube bezel for aquabay
Montag, 27. März 2006, 18:19
By request, Aqua Computer sells the aquatube bezel from the Baydream system separately.
edboswell
Re: new aquatube bezel for aquabay
Montag, 27. März 2006, 20:25
will there be a black version?
Ze@lot
Montag, 27. März 2006, 21:03
looks great, but mounting the aquatube like that is gonna be hard to use the side fittings, if you dont have room underneath. i always asumed that the reason, the aquabay had that weird 45deg angle was to keep everything within the 2 bay dimension. you prolly gonna need 3 free drive bays just to fit 1 aquatube :-/ unless there is a revised aquatube on the cards ;)
still looks great tho, maybe at the expense of a few drilled holes.
bugger i just remembered my aquabays are mounted right above my aquadrives.  :-/
Nitrix
Montag, 27. März 2006, 21:45
sweet - orders
