• 26.01.2026, 04:48
SNIFFER
Aquameter
Freitag, 23. Juni 2006, 18:10
Where is pin number 1 on the Aquameter so I can connect the UBS cable to it correctly
Infiltraitor
Re: Aquameter
Freitag, 23. Juni 2006, 18:52
You're on about the Tubemeter I guess.
Pin 1 = GND is the side with the slightly longer profiled section of PCB sticking out.
Similarly, Pin 1 = GND is on the L/H side of the header pins on the back of the Aquaero; the side next to the Flowmeter connection.
SNIFFER
Re: Aquameter
Freitag, 23. Juni 2006, 19:28
Yeah sorry, it is the tubemeter I was on about. Thanks now I know for sure.
SNIFFY
