• 31.12.2025, 15:22
zifnab26
7900 help
Samstag, 9. Dezember 2006, 01:41
Hi all
I just got my cooler for the 7900gtx and i was wondering if it made any difference that the core is a silver colour instead of red.
Also could someone tell me which screws go where as the instuctions are a little vague  ???
Thanks
Nitrix
Re: 7900 help
Samstag, 9. Dezember 2006, 15:57
Hi there,
The reason the core is silver is that AC have recently changed the colour of there core to silver as used in the core pros on other cards.
as for the instructions ill see if i can dig you up a better copy ;)
zifnab26
Re: 7900 help
Samstag, 9. Dezember 2006, 21:49
Thanks for the reply - I was a little worried there.
Any help with the screw placements would be great, i really dont wanna mess this up.
