• 21.03.2026, 14:10
daherik
Is this temp sensor compatible with aquaero?
Dienstag, 16. Januar 2007, 13:08
Hi another thread from the new aquaero user on the board.
I want to monitor the water temp on a couple of places in my loop. Is the following sensor compatible with aquaero?
http://www.dtekcustoms.com/index.asp?Pag…WPROD&ProdID=48
Thanks in advance for your answers!
Re: Is this temp sensor compatible with aquaero?
Dienstag, 16. Januar 2007, 14:20
Should work (10k Ohm).
