• 09.01.2026, 06:36
chung212
aquaero 4.0 fiash firmware fail
Freitag, 2. Januar 2009, 06:19
Hello!
when I flash a new firmware to my aquaero
My system hang
so I restart my system
but now my aquaero nothing display and all the fan stop
What can I do?
Freitag, 2. Januar 2009, 20:47
Try a reset but it is very unlikely that it will help... :S
Shutdown the system, press and hold the set button and power the system again. If it works, you will see a reset message on the display and you can release the button after two seconds.
Well, if it does not work you will have to return your aquaero for a check and repair.
chung212
Samstag, 3. Januar 2009, 06:16
I think need to return my aquaero for a check and repair!!
