• 23.02.2026, 12:11
BetterRed
Ultrastream Ultra - Intermittent 10W usage, flowmeter disconnects
Freitag, 16. Januar 2009, 19:49
I have had this problem with the Ultra since getting it, around 8 months ago.
The Aquasuite reports a doubling of power to 10W, though the frequency is constant at 61Hz. The attached flowmeter shows 0L/h, and the cooling ability is severely limited.
The only way i can find to fix it is to suspend the computer. It is ok after resume ... until the next time.
I'm wondering if i should RMA it? It is usually a minor issue, but on one occasion the system overheated badly.
Running Vistax64_SP1 - Aquasuite 4.64.00.
Samstag, 17. Januar 2009, 01:51
Which firmware is installed on your pump?
BetterRed
Samstag, 17. Januar 2009, 11:39
The FW is 1009.
