• 05.04.2026, 01:23
Beun
Twinplex pro on Ati Sapphire HD 4670
Freitag, 6. Februar 2009, 18:42
Just received the Twinplex pro ATI - http://shop.aquacomputer.de/product_info…roducts_id=2077 - and wanted to fit it on a Ati Sapphire HD 4670. But the holes do not match :(
Am I doing something wrong?
Papa_Schlumpf
Freitag, 6. Februar 2009, 19:52
it doesent need to sit strate. Will the holes fit if you turn it ... lats say 40° ???
Beun
Samstag, 7. Februar 2009, 23:49
Nope, even then the distance is just a bit to big :(
Any other ideas what's wrong?
Top_Nurse
Sonntag, 8. Februar 2009, 05:24
Do you have the correct mounting screen? Click me for details.
Whenever I buy AC blocks I usually order at least one of every mounting screen so I got options. 8)
