• 18.03.2026, 11:49
Birks
Clarification Needed
Freitag, 23. Februar 2007, 22:21
1. If i buy a aquaduct 360 XT externe Wasserkühlung mit aquaero
What tabs will show up in aquasuite?
2.Is the solution sufficient to cool 1cpu(X2-4400),2 Chipsets(Nvidia Nf4), 2 Volt Regulators,2 Graphic Cards (GF7900GTX). 4 aquadrive dual (6*7200rpm and 2*10.000rpm) and 4 sticks of DDR2(PC3200) All running on stock speeds, and still operate with low noise?
Re: Clarification Needed
Montag, 26. Februar 2007, 21:42
all tabs are same with the aquaero, only the overview page is a other.
this configuration runs without any problems with low noise.
The noise is dependet on the water /ambient temperature. (if your System runs with 35°C water temperatue, it´s very silent in the majority of cases)
Sebastian
