• 05.04.2026, 11:34
randomly
Trojan Horse BackDoor.Delf.CLA in Aquasuite 4.64 and 4.65
Dienstag, 24. Februar 2009, 13:01
I have an Aquaduct 360XT which I'm very happy with (pump could be a little quieter, but that's minor). It's quiet and works great.
The issue I do have is that AVG anti-virus identifies a Trojan Horse BackDoor.Delf.CLA in the Aquasuite_setup_4.64.exe file
It's also present in the 4.65 version.
Do you have any information about this?
Thanks
Papa_Schlumpf
Dienstag, 24. Februar 2009, 14:43
its a controlling software.... It ready parameters out of you system... of couse thinks the program thats a trojaner... come on its logic ;) Tell your program its ok... :thumbup: :sleeping:
Dienstag, 24. Februar 2009, 17:05
It is a false alarm caused by too high settings for the heuristic.
You can check it at http://www.virustotal.com/ if you don't trust it ;)
randomly
Mittwoch, 25. Februar 2009, 15:50
Thank you
