• 04.04.2026, 18:21
Top_Nurse
Radiator fan spacings????
Montag, 23. März 2009, 09:30
I'm getting a bit fidgety about fan spacings that are on the 240 grills I'm buying. Thje ones on my EVO radiators have a 17mm fan spacing, the ones from BI radiators have 15mm fan spacing, and the radiator in my Aquaduct has a 15mm fan spacing.
So the kicker here is that the previous link says that the grills will fit either the Evo, Airplex XT, or Pro radiators. So what fan spacing is on the new AC grills?
The 240 Grill I already have has 17mm fan spacings AND does not fit the radiator in my Aquaduct, but does fit the EVO 240 radiator I have (which is also 17mm).
So do the new gills actually have 15mm fan spacings or have they elongated the holes to account for both 15mm and 17mm fan spacing?
Montag, 23. März 2009, 22:25
Teh current grills have long holes - that is the trick ;)
