• 23.02.2026, 04:27
Sammitch
GTX260 55 vs 65 nm Compatibility
Freitag, 21. August 2009, 00:21
I'm looking to get a couple aquagraFX 260/280 coolers for my 65nm GTX260s, but I just want to make sure that there is no conflict between the 55 and 65 nm revisions of the chipset as there are slight layout changes between the two. A comparison between the two can be found here.
Thank you in advance.
Lumi
Freitag, 21. August 2009, 18:22
I don't really understand your question. What do you want to know? That you can use a 65nm and a 55nm in SLI without problems? Yes you (we :D ) can! And the layout is that much different that there are seperate coolers for the 65nm and the 55nm layout.
I hope that I could help you. If not, maybe reshape it that I understand it in the right way...
Freitag, 21. August 2009, 19:38
And there is also a third block for the 260.
