• 11.04.2026, 15:35
Top_Nurse
Aquaero LED setup wiring
Freitag, 4. September 2009, 12:26
On the stock LED setup, that connects to the Aquaero, does the red wire go the the (RED +) and the blue wire go to the (Blue +)?
KatanaArthur
Samstag, 5. September 2009, 17:52
Yes, you mean the Multicolor Module ?
the red wire is the positiv wire for the red LED an the blue wire the positiv wire for the blue LED.
Mein EYE 910 Gehäuse im umbau --> Klick <-- @ Meisterkühler.de
Und nicht vergessen... immer schön flüssig bleiben :D
Top_Nurse
Samstag, 5. September 2009, 21:50
Thanks as I'm rewiring mine to use a single multicolor LED (red/green/amber) and need to know so I wire it up correctly. :thumbsup:
