• 23.02.2026, 05:26
Top_Nurse
Aquaero relay in start up mode question
Freitag, 11. September 2009, 07:26
I am considering not using an on/off button at all on the exterior case. Will there be any problems if I wire the Aquaero relay directly to the start terminals on my motherboard?
Freitag, 11. September 2009, 09:23
Should be no problem because that makes allmost no difference compared to people who connect it parallel to the power button.
Top_Nurse
Freitag, 11. September 2009, 15:13
I thank you and my case mod Feeding Frenzy thanks you as well. :D
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Top_Nurse« (11. September 2009, 15:14)
