• 27.01.2026, 09:37
Sniper101
Pleace help with gtx260 55nm waterblock
Freitag, 2. Oktober 2009, 19:32
Well guy's i finally reciewed my gtx260 superclocked 55nm 896-P3-1257-AR.
But i was lucky enough to get the crap revision i didnt want the version i wanted is this see link:
http://www.flickr.com/photos/4173419...n/photostream/
But instead i got this one, the exact same one as in the link below:
http://www.xtremesystems.org/forums/...d.php?t=232917
I already asked EVGA if the 896-P3-1257-AR has the same layout as in the first pic (link)
They said yes.......that was not funny of them
Asked EK if the EK fc260 55nm is compatible with the first link picture they said yes
Unfortunatley i got a newest revision, all my research infain for nothing. My head hurts of all of this.
Is it possible to use one of your Aquacomputer full cover gpu block for the card i have now?
Since the pcb of the gtx260 55nm and gtx275 are the same visualy see
link:
http://www.flickr.com/photos/41734199@N03/3975050254/
Any suggestions?
Thanks in advance
Freitag, 2. Oktober 2009, 22:57
This block will work.
