• 23.02.2026, 16:16
pinguano
Noobish question
Donnerstag, 29. Oktober 2009, 15:41
Assumed that aquaero is connected via usb to the motherboard: aquastream should be connected to aquaero via aquabus EXCLUSIVELY or should I also connect the aquastream to motherboard via usb? (ie: aquabus or aquabus+usb?).
thanks
a poor noob
Donnerstag, 29. Oktober 2009, 16:01
You can also connect the pump via USB when it is already connected via aquabus. In this case you will ba able to use all functions from USB and aquabus :)
