• 11.02.2026, 23:26
Ytterbium
Manual Build of A77 system
Montag, 2. November 2009, 00:14
I already have a Lian-Li A77 system, what parts would I need to build up a system that would be the same as purchasing the whole thing from Aqua Computer?
Is is possiable to fit the aquero in the slot where the A77 has the temperature read outs?
Thanks for you support.
Mittwoch, 11. November 2009, 10:22
Listing every single part would take some time so just the most important things:
- laser-cutted top (not for sale, can be done if you send it in)
- radiator airplex 360 XT with three fans
- aquastream XT standard with mounting plate for radiator
- aquaero
- connectors
- tubing
